The purpose of the
Kit Restriction File Editor is to provide an easy method to creating
kit restrictions for Multi-Player play. It creates .kil files that
are stored on the server and can be changed in the edit server
window.
This part of the site is still under construction until I have more
time to play with it.
Here is a picture of the Kit
Restriction File Editor in IGOR:
It appears that you
have a list of kits available on the left. Select a class (rifleman,
demo, support, sniper), highlight the kit that you want to add,
click on the add button. There is a create new button on the bottom
as well as a load button to edit an existing kit. The save button
saves your kit restriction file.
